After restore the backup, I see changes in the home(mainmenu.php)
plaese Help me I am waiting for your reply.
maybe some problems with your hosting?)
а языковой lng файл на месте ?
wapsun, what hosting you use?
use VPS from wooservers my Previously control panel is Directadmin but im change to Control panel so must Reinstall server(Centos 6) Now i use Virtualmin panel(I've never had a problem with the control panel and got to work.)
All pages are no problem, other than the home page
I've had such a problem had arisen in DirectAdmin. The problem was solved by turning off safe_mode = Off & open_basedir = Off.
Your new hosting is not support PHP language or you just not enable PHP for current domain in hosting control panel.
wapsun, sometimes I have such problem on my hosting when files copied with error, so try to copy your backup to the hosting once more
if it's only in mainmenu.php, you need only this file
I found the solution. thank you L!MP and Jane
PHP language Was inactive
PHP script execution mode option FCGId (run as virtual server owner) im change to Apache mod_php (run as Apache's user)
wapsun, mainpage.php change <? => <?php
else short_open_tag = on php.ini
Koenig, I've changed mainpage.php <? => <?php
Also short_open_tag = on in /etc/php.ini
